sm2596 said:Hi Martin, thanks for all the hard work you put into this![]()
I was wondering if you could please add fan monitoring for the Clevo P650RE series?
It's also branded by Metabox, and in the BIOS it's "Notebook P65_P67RGRERA" so I think that means its the same for the P650RE, P650RA, P650RG, P670RE, P670RA, and P670RG
If I'm not wrong, the P651xx series is the exact same with just a different exterior on the laptop.
The offsets from RW are:
I'm sifting through the DSDT dumps to try to find the relevant manual toggles for fan control, I'll let you know if I find anything because they might correlate with other laptops as well.
- 07: CPU Temperature (I can't find an offset that changes for GPU temperature, I'll keep digging)
- D0,D1: CPU Fan (Using the same 32768*60/N as others have stated)
- D2,D3: GPU Fan 1
- D4,D5: GPU Fan 2
All I know so far is that toggling max fan speed with Fn+1 changes 0xCC to F3, and toggling it back of sets it to F2. Unfortunately 0xCC seems to display the most recent hardware change (i.e. caps lock, num lock, airplane mode, keyboard backlight all change the value, overriding the previous one) so it's probably not that useful
Right now the Clevo Control Center GPU OC tool lets you manually control a positive fan speed offset, so fingers crossed it leads somewhere![]()
Thanks again!
Martin said:This model should already have support for fan monitoring in HWiNFO. Is this not working at all, or just some information is missing ? Is the Clevo EC sensor shown in HWiNFO ?
earnack said:Hope this helps with the conversation. Did not see the info for fans on the p650 boards
I have a p650hs-g with the discrete graphics enabled by default. I know there are three fans on board.
Here are the files I created to hopefully get the fans info in the next build. Hoping to eventually read/learn how to get them to the rain-meter plugin. Other default sensors are working in rain-meter.![]()
Martin said:earnack said:Hope this helps with the conversation. Did not see the info for fans on the p650 boards
Please also attach the EC dump from the RW Everything tool as described in this thread.
mtuan293 said:What do I have to do in order to help you with this, Martin?
Martin said:mtuan293 said:What do I have to do in order to help you with this, Martin?
I will need the HWiNFO Report File and EC dump made using RW-Everything as described in this thread.
Martin said:Here it's just morning
It need the fans to be spinning when creating the EC dump, can you make such? Also how many fans are there?
Martin said:Thanks. That model will be supported from the next build.
