Tooltips mostly all not working
Arctucas
Some of the group heading, but not all, tooltips work.
The only item tooltips (all are GPU items) that work are:
GPU PCIe +12V Input Voltage
GPU Total Board Input 2 Power (sum)
GPU Core (NVVDD1) Input Power (sum)
GPU Core (NVVDD2) Input Power (sum)
GPU Core (NVVDD) Output Power
Total GPU Power (normalized) [% of TDP]
Performance Limit - Reliability Voltage
Performance Limit - Max Operating Voltage
Performance Limit - Utilization
Performance Limit - SLI GPUBoost Sync
I have attached the debug file (I had to compress with 7-zip because it was too large), and the report file.
  • USER.HTM
  • HWiNFO64.7z
Downloaded 8.02, still not working.
I actually rely on the tooltips to help identify the sensors and what function they perform.
Would really be nice if they started working again...
Mr. Malik,
I realize you are very busy, but I was wondering if you had made any progress with the tool tips issue?
Regards
