Disabling "CorsairLink and Asetek Support" will just disable support of those devices in HWiNFO but can't solve the problem that iCUE is blocking others.
Clicking "Ignore" will disable all future warnings. To enable it back, you'll need to either delete the HWiNFO64.INI file or remove the following line from it: "DisableBlockingWarning=1"
