Spikes on VSOC Voltage (MSI B850/9800X3D)
Hi, i recently turned EXPO on on my pc, i see 1.2v is the default vsoc. But i noted vsoc spikes especially in the cpu sensor (VDDCR SOC).
Ppl told me that it must be a sensor bad reading, because vsoc its supposed to be static.
I saw spikes up to 1.287v from 1.2v on the ps3 emulator (very heavy) on the cpu sensor, and on the motherboard (CPU NB/SOC) is normal i think, from 1.21 to 1.23v max.
I also saw patch notes on the upcoming versions that say improved sensor reading on b850 mobos, it could be a bug on hwinfo?
I'll leave some screenshots below. (VDD MISC also spikes a bit)
CPU heavy game, tlou part 1 (a lot of shader compilation)
5m cinebench r23 loop
GoW on PS3 emulator, very cpu heavy
The same "issue" is discussed extensively below
Yeah i saw them yesterday, so it's supposed to be a sensor error? not a real problem?
Maybe some program interfiering with the readings...
In my case i only have adrenaline (cus amd gpu), and afterburner (every metric disabled, i only use it for gpu fan control)
