punctuation numbers
exe
Currently, HWinfo displays numbers as (example) 12,345,678.12 = comma as thousands separator and dot as separator between integer part and fractional part.
In my country this is the other way around
so I am used to (example) 12.345.678,12 = dot as thousands separator and comma as separator between integer part and fractional part, this is for me easier to read.
this can be a setting in the main settings with the possible choices in a drop-down list:
45,678.12 (comma as thousands separator and dot as separator between integer part and fractional part)
45.678,12 (dot as thousands separator and comma as separator between integer part and fractional part)
or get from the operating system as a user setting from the localization (but this might require more work)
I prefer the English language and the 45.678,12 (dot as thousands separator and comma as separator between integer part and fractional part) as separate settings
edit: I am using HWinfo64 v8.20-5640
thank you for your fast reply.
this needs to be changed for each value separate, so I am not doing this separate for each value.
is there a way to set all values at once (one setting) with dot as thousands separator and comma as separator between integer part and fractional part?
