Power Reporting Deviation Nowhere to Be Found
mgilbert
I have an AMD 9700x CPU on an Asus X870 motherboard, and the "Power Reporting Deviation" in HWINFO is not showing up! I've found some "solutions" online, mostly about overclocking causing this issue, but I'm running the board and CPU stock. It's also been mentioned that this parameter will not show unless the CPU is under a 100% load, but it doesn't show up then, either.
Any ideas???
