LAN Temp not showing
ACE
When I connect to the other PC via LAN, it doesn't show the temperatures of one of the hard drives, even though the temperature is visible on that PC. However, it doesn't show when connected via LAN. Everything else is visible.
That's really weird.. Try to run HWiNFO on the remote system for a while and then reconnect it.
You might also try to set the SMART polling to every 1 cycles.
I've tried everything, reinstalling, the non-Beta version, the Beta version. I deleted the LAN connection, re-created it. Nothing. It doesn't show the temperature of this hard drive only, but only on the LAN. It shows it on the host machine.
And the SMART polling? Check in sensor settings.
I don't want it to retrieve the data so often because I'd still be using the hard drive for a long time... And I don't know what that has to do with the problem. As you can see, it's just a display error...
Which HWiNFO version are you using? If 8.20, try older v8.16 on the client system.
