RickJamesBish
Running Intel Diagnostics on CPU while watching HWINFO 64 CPU Core Temps. The current readings were reset prior to running so CPU was sitting around 29c. Ran the test, watching the current and max columns for Core Temperatures. The current temp never shows a reading in the 80s, however the maximum showed 89. I am able to reproduce every time. Not sure if that is intended but seems max would be whatever max temp was reached in the current column.
