hwinfo temperature unit show as "?" in osd (RTSS)
Do you use HWiNFO's built-in RTSS OSD to export data to RTSS, or importing data into RTSS from some other app like MSI AB with the HWiNFO plugin?
Yes, I use the HWiNFO's built-in RTSS OSD.
I noticed another problem. HWiNFO uses different Celsius symbols in different languages. For example, Simplified Chinese uses "℃" (a single symbol), while English uses "°C" (two symbols, "°" and "C"). The latter can be displayed normally in RTSS by modifying the font, but the former cannot.
Yes, that's the reason why you see a problem in RTSS. Chinese simplified and traditional require a different encoding for this symbol but HWiNFO converts it to be properly interpreted in RTSS.
Are you perhaps using some custom settings in HWiNFO? Do you run HWiNFO with Chinese (Simplified) language?
Yes, I used some custom settings in HWiNFO. And I run HWiNFO with Simplified Chinese.
I noticed the Celsius symbol is different in the custom settings when I switched from Simplified Chinese to English. As I mentioned earlier.
My current solution is to change the temperature unit in the custom settings from "℃" (a single symbol) to "°C" (two symbols, "°" and "C") in the simplified Chinese environment. Then use Vector 3D or Raster 3D in RTSS. When using Raster 3D, I need to change the font. The default font of RTSS will display "°C" as "?C".
